Replacement for P5B Deluxe
jshuler
Need a replacement for a P5B Deluxe as Newegg is out of stock. Going to upgrade the processor to an E8400 at the same time, what motherboard(s) should I be looking at?
Thanks,
js
First I recommend getting a Q6600, it's the same price and what would you rather have, two cores at 4.0 or four at 3.6? Good mobos are P5K-e/Deluxe/Premium, DFI DK P35, IP35-Pro, DS3P/DS4 and Neo2-FR just off the top of my head. What do you need in a mobo? Overclocking or running at stock?
The system is mostly used for video editing. Not looking to overclock at this time.
Definitely go for quad. If all you need is a simple mobo with no frills (i.e. no firewire, etc.) then the DS3L and IP35-e are highly recommended.
