Replacement for K8N Neo4 Platinum
  • Thread starter Deleted member 80897
  • Start date
D
Guest
well i waz going to order a K8N Neo4 Platinum http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=637
but my retailer doesnt seem to have that board and now im thinking of another brand for the board...
how is DFI none sli and Asus compared to the MSI board?
im gonna run a X2 3800+ cpu, Corsair TWINX1024-3200XL 2x512Mb on it ...
the thing is that i also plan to have Zalman passive northbridge thing and the zalman resorvater plus ... so the board has to manage that ...
sorry for the bad english :)
The MSI is a good board,
Don't you have another retailer you could go to?
DFI's are also great as long as your into fiddling around with your settings to get the best out of your setup.
stick with MSI, just find another place to buy it.
Not to hijack or anything, but didn't [H] give that board some bad marks?
-Freeman2k6
Yes, that was pre 3.5 bios. With the new bios' you will see that this board is very nice and stable.
Originally for those that don't know, winchester processors had a hard time overclocking on this board. My issue was rectified with the Diamond bios 1.5 and the Platinum bios 3.5. The 3.6 bios' are even better.
So this board is not only safe but very good now.
according to the MSI download site I only found a BIOS ver 1.5 for the Nforce4 Platinum...the 3.6 was the SLI version...
Yeah I've heard that the new BIOS updates have greatly improved pretty much everything, so it seems like a safe buy if you plan on updating the BIOS.
Its a shame that hardware reviews can't be kept up-to-date to let future readers know what the hardware will be worth by then (if it's gotten any better or worse). I guess the next best thing is to look into these forums for people who have experienced a specific piece of hardware, and get some feedback on it.
-Freeman2k6
Well originally, in their initial review for the SLI edition was the HardOCP "must have" winner. This was with NewCastle and Clawhammer procs. It turned out for a period of time, that certain steppings of the Winchester core had a POST problem when trying to overclock by the BIOS. We Winchester owners could get around this by running Clockgen, because the problem didn't occur in Windows (just during BIOS POST). Venice and San Diego owners were back to OC goodness, and all are extremely stable with 3.6 as the BIOS rev is currently. MSI also supports the X2 cores officially on their CPU listing, so it's a good board for those procs as well.
So the marks against it were during the Winchester phase. New proc purchasers wont have a problem. Just avoid the Winchester core. The newer Venice and San Diego cores also have better memory controllers as well, so one addiitonal reason to go with those newer cores.
The non SLI Platinum also has a new stable BIOS that yields similar results. Personally, the cost of the SLI edition is worth the cost. You don't have to go with a second card (but it's there for the future if you "ever" change your mind without having to buy another board) and several have used the Zalman passive northbridge heatsink with the SLI board (trimming a section of the HS fins will also allow it to be compatible during SLI use as well).
For the extra price, besides the SLI featureset, you'll be getting a much better audio solution (Creative Labs Live! 24-bit/96KHz, Dolby Digital EX), second Gigabit ethernet adapter (PCI-E based, not like the PCI solutions of the ASUS and DFI) and extra SATA II (or more correctly stated SATA+IO 3Gb/s capable) ports (SiI3132 PCI-E controller, not the PCI SiI3114 controller the competition uses that is also only SATA "1.5Gb/s")
I really love this board, have had it since Feburary and had gone through the BIOS testing and upgrade phases to see this become a truely solid board. Go for it.
Here's a link to Newegg for the board if you are interested. I think you'll find pricing to be good here.
http://www.newegg.com/Product/Product.asp?Item=N82E16813130487
Thanks alot...very informative. Looks like a better board than the ASUS I was looking at...for anyone else intersted, zipzoomfly seems to have the best deal right now...$144.99(that's including a $25.00 rebate)
Regards,
-Freeman2k6
well i waz planing to get the platinium SLI-edition at first but then i found out that it had to have -5volt and the Creative Labs Live! 24-bit/96KHz, Dolby Digital EX could be a problem ... i already have a Creative Labs audigy2 THX soundcard that i plan to use so the extra cost for the SLI seems like threwing money in the lake ... i also know that i wont be using SLI cuz i wont be playing any graphic intense games on this computer ... the graphic card im getting is a MSI 6600GT ....
i found another retailer that have the board im looking for and they also have the other parts im gonna get ...
Well.... enjoy. If it helps the -5V is no longer a requirement. The boards shipping now are modded to not require that. If you look at my sig, you'll notice I'm using the board with an Enermax that doesn't provide the -5V requirement, or used to be requirement. You'll notice that I'm also using it with just a single 6600GT, just wanted the flexibility for the future. I pitched my Creative PCI card as the onboard is exceptional, but if you've already got a THX card. (Didn't know about the THX certification).
But you'll be happy with your non-SLI Platinum board as well. So no worries.
thanx for the nice info ... now im not worried at all ...
A good freind of mine just got this board..NICE :D
I myself was going to buy the Asus Preimum..now after helping my freind set his system up..I like the lower in price and just as good as the Asus :eek:
