replacement fans for sn85g4v2?
rusty
im buying the SN85G4V2 and was wondering if i should replace any of the stock fans. i heard that the V2 has better cooling but wasnt sure if i should replace any of them. any input would be helpful, thx
Since you are getting a v2 you might want to check out how well the fan performs before replacement. The v1 came with the Sunon 80mm fan that was loud if cranked to full blast. The v2 fan has more fins and supposedly does a better job of expelling heat. Same question as above, do you want performance or quiet? SilenX for quiet, and there are several recommendations for performance.
Regards,
-E
