D
Deleted member 12106
Guest
Hi, I have this twin turbo boeng 747 switch.
The switch is a 3com SS2, I dunno the model number, too lazy to turn it around(it is in use).
The fans are so friggin' loud. I can hear it thru the floor and over my xbox when it is quiet.
Does it need the fans? It has 3 in it, I do not put it under strenous load often.
I would like to replace the fans in the switch. I have opened it up b4 to look at the fans, but, I am worried about replacing them with something and then it is not enough to cool the switch...
Anyone know of a good QUIET solution? The drone from it, it is like a 60mm tornado...make it stop...
