Replacement fan on an HSF
pjaank
Hey all. Finally jumping up from a slot a to a socket a (Asus A7V266-E with a 1400+) thanks to a forum member selling off some older hardware. Problem is, the HSF fan (stock AMD cooler) is buzzy as all getout. Any recommendations for a replacement fan? Prolly just run to Fry's tomorrow to get a new one.
I have the SI-97 from Thermalright, but that may be overkill for a 1400.
Thermaltake Silentboost maybe?
Well, I'll poke around to see what Fry's has. Hoping I can just replace the fan, and not have to worry about the whole hsf.
If it is just the fan that is going bonkers, then try oiling it.
Scratch that. I pulled the fan off, so I could use it to get a measurement/comparo. Ran it off of the heatsink, sounded fine. Blew everything off, put it back on, now it's quiet. It just sounded before like it was hitting something as it spun. Well, seems ok now!
Did notice (just now) however, that the fan is blowing INTO the heatsink, rather than away from it. Is this just how things are done on the Athlon XP coolers? Tried flipping the fan around, but the screws aren't quite long enough. Currently, the Asus Probe software reports a CPU temp of 48 C (118 F), with a case temp of 25C (77F). Ambient temp in the apartment is around 72-73 F.
Every HSF that I have had has blown onto the HS.
Those temps are with the proc running at 1050 mhz. Just bumped it up to 1400, and letting the machine run for a bit, so I can see what the temps will do.
Ah, good to know. Previous experience was with a Slot A cooler, which blew more outward.
