Replacement Fan for Golden Orb
wolfsburged
I have a Golden Orb CPU cooler which I've modded onto a videocard. The fan on it has gotten a bad bearing or something and is making a racket. I cannot find just a replacement fan for it. I don't feel like buying an entire Orb just to replace the fan. It is thermally epoxied on, so its a pain to switch coolers and its working fine, aside from the noisy fan.
I bought a generic 45mm bury frame fan:
http://www.directron.com/ec4510m12sb.html
but this is about half as tall, and it looks a lot whimpier than the original. I don't want to risk screwing up the cooling...
Any ideas?
buy another Golden Orb and replace the fan. :D It is the safest way to do this....
Please contact our parts department at (800) 988-1088 ext 108 from 9am-5:30pm PST Mon-Fri regarding the price and availability of your part.
