Replacement Fan for 7800GT
MChief
Hi,
I've got an evga 7800GT and the fan is getting a bit noisy. I could RMA it but I'd rather upgrade it anyway.
Can anyone recommend a *quiet* heat sink replacement?
I'd really be down with a dual slot solution using a larger fan, but I plan to SLI it at some point in the near future so the solution can't be too crazy.
Grassyass.
i would reccomend the zalman fanless heatsink for noiseless cooling
Zalman VF700 will keep your card cool and quiet, VF900 if you plan on volt modding.
Arcygenical said:
VF900... It's so cheap these days...
Good point, might as well go with the vf900 considering the price. The 900 is also slightly thiner, meaning fitting two in SLI isn't as problematic.
Installed it without incident. It is silent on the lowest setting and keep things cool and overclocked. I would have prefered a dual-slot solution from Zalman to exaust out the rear but I'm very happy with this unit overall.
Thanks!
