Replacement CPU Fan
Snittako
Hi all I was building a matx machine and realized that my Sunbeam Core-Contact Freezer 120mm fan was not spinning. I tested the 4 pin header on the motherboard with another 4 pin fan and it started without a problem. I was wondering which brand or type of fan would be best for cpu cooling specifically in the 120mm size. Thanks for your input.
Thanks, but does the low speed mean it will be quieter. Also is it possible to control a fan through the motherboard with only a 3 pin header on the fan.
thanks a lot for the info. I ordered two, one for the cpu and one as an intake.
