I've got a HIS X800XL, and it's now on its second Arctic Silencer, the first one the fan just got so slow the card started to overheat & while this card was repaired (or replaced), the cooler is starting to get very noisy when the the system boots up. It's getting very dusty around here, so I'm wondering if dust is clogging up the fans, though having said that why are the chassis, PSU & CPU fans all working perfectly? Anyway if I'm eating Arctic Silencers what would people recommend? I'm thinkin' replace the cooling solution, in this respect it can be water or air a long as it fits in a Silverstone SG01 & if it's water will be able to take a CPU as well.
My first idea is a Zalman reserator, however I'm not totally convinced of it being able it to cool effectively with the 78mm headroom I've got above the CPU (ie sharply turned/kinked tubes.
