friend'scatdied
- Feb 20, 2005
My bracket is kind of funked up. At the top the screw holes are a little warped and it doesn't secure properly into the slots.
Is there any easy way for me to get ahold of a replacement bracket for it? The brackets between the 57x0's and 58x0's are identical BTW, according to visual confirmation.
This is the bracket I'm talking about. Was thinking I could just swap my funky one with a clean new one if I could get ahold of one.
I think I'm just gonna dremel it a little bit or something. It's as if there was simply too much metal and the screws won't fit 'cause of it.
