Replacement bios chip?
piehole
Hey guys, long story short.
I'm sure the bios on my GA7 N400-L is corrupt, i overclocked my FSB to 185mhz and it started giving me errors on reboot, cleared cmos etc and kept it on 166 and it worked fine until i turned my pc off. It then refused to boot back up seemingly taking my radeon 9800 pro with it :/
Anyway, i'm not using the gigabyte now, unstable piece of shite it is :) but i would like to get it working again for a second PC. So my question is, does anyone know of any decent and reputable UK stores who do replacement bios chips? Either a reflash or complete chip replacement would suffice. Also, although this maybe the wrong forum but does anyone know of any companys/stores/people that can repair/diagnose anything wrong with a 9800 pro? I can't return it due to it not having the stock heatsink on so heh.
Cheers in advance for any help :)
Just realised the board may not have a socketed Bios chip. So if any of you gigabyte guru's know anything about replacing the bios etc it would be helpful. :)
Photo enclosed, bios chip is bottom right.
I thought all of gigabyte's new motherboards were dual bios? Well if not, that really stinks dude. If it were socketed, I would say just do a hot-swap. I killed my bios once, my buddy had the same motherboard as me. After an hour of research, we got the correct bios, got all the "parameters" correct, and fixed my bios. Quite cool... I do say if there is a Radio Shack, pick up a PLCC socket remover, made life alot easier. But thats pretty irrevalent, yours isnt socketed:(
Not all aren't unfortunately. I was under that assumption when i first brought it because of the advertising on the box but it turns out to be a no no, which is a shame because as you said the motherboard isn't socketed.
Ahh well it's not all bad, forced me to go out and buy the DFI LanParty ULTRA B ;)
