I have 3 batteries that need replacing. I have had some issues with 3rd party batteries in the past with them not fitting properly and/or they died within a few months.
Are there any specific 3rd party vendors you all have used that have had good/great results with? Looking on Amazon and other online sellers, I see that there are just mixed reviews across the board.
Laptops needing Batteries:
2007 - white macbook
2011 - 13" MBA (internal battery is replaceable)
2012 - 13" MBP
Thanks!
2012 - 13" MBP
Thanks!
