replacement acrylic for Antec 900
rjolin01
I am looking to replace the acrylic on my Antec 900 and short of buying a whole new side panel or an acrylic sheet and cutting my own (wont have fan support clips.) I am wondering if anyone knows where I may find replacements? Thanks !
Where are you located? If you know someone with a laser cutter, they might be able to do it. (Depending on whether their cutter can handle a piece of this size.)
The time and cost of doing it yourself might be cheaper, but on the price at Antec site for replacement window side panel is only $16.95.
http://www.antec.com/Detail.bok?no=506
Or you could buy the other side panel, that should fit and then cut out your own window to the size you want. But then you would have to get the acrylic sheet and window panel molding to hold it in place.
http://www.antec.com/Detail.bok?no=547
http://www.performance-pcs.com/catalog/index.php?main_page=index&cPath=130_132
i think i may just try the 3 step acrylic cleaners some sites have and see what happens.
Google acylic and your city and im sure you have someone local. I bought a 15" by 24" piece for 10 bucks the other day.
