Replaceing power supply fan
Ender1183
The fan in my HTPC is really starting to get on my nerves. It is fine when movies are going but when its quite it really its loud. I am not in front of it now but i think its a corsair 650, i thought it was a 80mm fan. Any suggestions for a replacement,a way to adjust the speed or dampen the sound?
make sure to use a fan with a high MTBF , inside a PSU cooling is lot more crucial than your case; so a fan in there should not have sleeve bearing; best to go with some liquid bearing as the Sony
