Replaced WAP with switch, now no connection through switch?
Discussion in 'Networking & Security' started by patnshan, Sep 20, 2012.
  1. patnshan
    patnshan n00b
    11
    Sep 10, 2012
    Hello,
    I have my new router up and running. As part of the upgrade, I replaced an old WRT54G I had been using as a wired WAP and switch in my living room with a Trendnet 8 port gigabit switch. I was getting good connection of my TV, XBOX, Blu Ray players through the LAN ports on the WAP before. Now I replaced that with the switch and get nothing. I thought the switch was plug and play and I'd have to do nothing. The connection lights are on but the devices say they can't get an IP address from the router. Any idea why? For reference, I am using the Buffalo G450 router and another one of these switches In another room.
    Any idea what I should try next?
    Thanks,
    Pay
  2. AcidBurn
    AcidBurn [H]ard|Gawd
    1,426
    Apr 23, 2002
    Make sure their isn't a specific uplink port that has to be used on the switch and your going straight from the router to the switch.
  3. /usr/home
    /usr/home [H]ardness Supreme
    6,166
    Mar 18, 2008
    Sounds like the old WAP was doing DHCP. If you set a static IP on a device on that switch does it work then?
  4. goodcooper
    goodcooper [H]ardForum Junkie
    9,803
    Nov 4, 2005
    if it's gig switch they should all be auto-mdix
    i would test your router make sure the DHCP is still up on it and etc... sounds like something is wrong with the uplink though...
  5. patnshan
    patnshan n00b
    11
    Sep 10, 2012
    I checked and I had it router > switch > switch (which I thought you could do??). I changed it to router > switch and router > switch and now it works.
    Question though. Can't you stack switches?
    Thanks much!
    Pat
  6. goodcooper
    9,803
    Nov 4, 2005
    all depends on how they're configured...
