Nate_MachV
- Oct 5, 2006
Hi all,
I usually don't have too many problems with my computer but, recently I've been having issues getting it to post. It turns on for a few moments and then turns off after about 30 seconds, without going to bios or even giving my usb porst any power. I contacted my Tech Support (gasp! I bought a FNW computer) and they've been quite helpful, replaced my RAM with higher quality for no charge and have been helping me eliminate other possible causes.
I received my new RAM and installed it, the computer worked for a few minutes... booted up and and everything seemed to be working. But, it wasn't, it turned off before my excitement had gone. So now it seems I'm back at square one.
What I wanted to know is if there is anything I can do to try and get it to work without asking tech support again. This is even more complicated as I live in the Arctic where everything and anything I need has to be shipped by the only means accessible. Airplane. It's not as easy as running to the local computer shop for a new piece.
any help would be appreciated.
