Replace Wireless Card with La Fonera?
Thanatos.
So i have a La Fonera (one rj45 port version) flashed with DD-WRT and im getting a Shuttle SN25P which only has PCI-E slots so the wireless card i have now wont work for it. Im really not wanting to buy a USB wirless device and 1x PCI-E cards are hella expensive so my question is can i use the La Fonera to receive the wireless internet and pipe it to the Shuttle via ethernet cable? Is that even possible?
Since it has DD-WRT on it, you should be able to set it up as a wireless client and do exactly as you said. If I remember correctly its relatively easy to do within DD-WRT.
Yeah it only takes a few steps, just take a look around on the DDWRT wiki and there are a few tutorials on there.
abit makes a PCI-E 1x wifi card that is often $0-5 AR at clubit.com
