Replace PS or get VGA supply
Wicked_Bass
I have a Xclio 550BL right now. I just upgraded to a 8800gts with a new Intel Extreme Edition. I am looking to OC a little.
Is my current PS enough?
Was thinking about getting the ThermalTake VGA card power supply to help out?
AW8-MAX
Pentium 955 etreme
4 gig gskill ram
8800 gts
2 dvd drives
4 hds
sound card
6 case fans
Any info is much appreciated!
Xclio isn't exactly a top quality PSU manufacturer. If it was me, I'd replace the PSU. More power for future scalability and better quality and more reliable power to the rest of the computer.
What are you basing that on??
The Xclio power supplies are very good.
http://www.extremeoverclocking.com/reviews/cases/Meridian_XClio_450W_7.html
http://www.extremeoverclocking.com/reviews/cases/Meridian_XClio_550BL_7.html
http://www.tweaktown.com/reviews/829/4/page_4_final_thoughts/index.html
"After everything is said and done, the XClio shows itself to be a true performer."
"To be honest, I had some reservations before testing because Meridian was not a name I was familiar with. However, after giving both XClio power supplies the run-down, I was pleasantly surprised to see how well they performed (especially for a new product)."
"Meridian's new XCLIO-550BL is definitely a solid performer with good voltages and capable of meeting (and exceeding) its rated specifications. In fact, I was able to push this power supply to a peak of about 700-750W (however it did shutdown safely within about 30 seconds). Even under that heavy load I checked the 12V rails and they were still within 1% tolerance!"
OP, your 550W Xclio is *more* than enough. Don't worry about it and go to town.
