Replace 7950GT with what?
I have a 3-year old system with a Gigabyte 965P-DS3 motherboard and a 7950 GT video card. The fan on the video card recently started making an annoying loud high pitched whine and so I think I need to replace it. The 7950's performance is ok for me, but I'm willing to buy a card with better performance as long as it costs under $100, preferably under $75. My video needs on this PC are pretty minimal: I originally got the 7950 to support HalfLife 2 and Counterstrike. If they release a new update to HalfLife I will probably try that, otherwise no gaming.
Let me know if you have any advice on a card that (1) will work on my system, (2) is better than the 7950 GT, and (3) costs under $100, preferably under $75.
Thanks in advance!
Something like an nvidia 9600GT or an amd HD4670 would work fine, both about $75
If you don't mind buying used,on the forum they have 4870 and 5770 for ~ $100.
Too bad it's not a few months in the past...260s were commonly going in the low-$100s AR for quite a while there :(.
Alternate idea... Is there any kind of stability issue with your card now? If it's just the fan going out, you could replace the HSF for $20, $30 max. It's long since gone from the market, but I replaced the stock HSF on my old EVGA 7950 w/ a AC Accelero (rev 1 if I recall) - paid like $16 for it. It dropped temps from mid-high 80s to low 60s (passively run; 250mm side panel fan in my case tho), if I recall.... There's no sense in upgrading IMO, if you're not having performance/playability issues, not looking to play the much more demanding recent stuff, aren't looking to up your res, and so on...
[edit] For example, SVC has the Arctic Cooling S1 rev 2 @ $25. I thought even the r2 was long gone... Says turbo module/fan is required, but I'd venture to say that if you've got good airflow in your case, esp. w/ a panel fan blowing in the general direction at least, you can run passive/pseudo-passive no problem.
