I accidently got the corner of my case's panel caught on one of my sata cables and the port that was connected to the sata cable on the mobo broke off.
Am I down one sata port now or can it be repaired?
IF you didn't twist it when it happened it can be repaired with good slow setting super glue. Just make sure you realign the pins on the port with the piece that broke off. They kinda slide into place on the inner part of the connector. I did that to a hard drive a while back trying to stash wires a little tighter and it is still running as it did before "Captain Stupid" intervened.
