reoccuring hd problem
KillToy
ok least week i had a problem where i couldnt get windows to boot, i tried booting from a floopy, a cd and nothing was working. Everything i tried would end in an error message aboud windows being shut down to avoid damage to the computer. I ran maxtors powermax bootable floopy and it scanned the disc for errors and foud several errors, after running powermax i was able to start up with no problem at all. Now about a week later I have the same problem, i am at school right now but i will run powermax when i get home. What is causing this? Is the HD going bad or is there something that i am doing to cause this?
Edit: Also sometimes when starting up the comp will say "system failed memory test" instead of the usual "system completed power on self test" but the computer would just restart and everything was fine. Could this have soemthing to do with me turning everything (including the powersupply) off at night?
that sounds a lot like a ram error might be occuring. download memtest and run that.. see if you get any errors. the hd errors might have only been a coincidence.-the_nerd
Generally utilties can be found with little work by adding a .com or .org extension to the name. Hence memtest86 is memtest86.com, memtest86+ is memtest.org, the ultimate boot cd is ultimatebootcd.com, and so on. If you can't find it after two or three tries, google will have it. Provided you have a spare CDR, grab the UBCD, as it has memtest on it, among other things you may need later.
