Removing Zalman memory heatsinks.
PoweredBySoy
Does anyone have any experience in removing those 'sticky' video ram heatsinks that come with the Zalman units. Is there a certain technique I should use?
Thanks.
you could try using a hair dryer to warm them up a bit then slowly twist them back and forth until they give way. i would only pull on them once they seem a little loose first.
iF these are the blue ones that u speak of...here is what i did...
I got some 91% rubbing alcohol, got a syringe... fulled it up and injected it in the white tape.... It worked lol but probably not so practical nor safe if you don't know what ur doing.
