Removing Xigmatek heatsink???
If you used the adhesive tape on the back plate, you can just leave the back plate in place when you remove the heat sink. You don't need to redo the back plate when remounting the CPU.
oh .. lol how stupid of me. I'll leave it alone than. Thanks for the suggestion
btw do you know if you have to put on new thermal paste after taking off a heatsink? And clean the old stuff off? I just want to make a minor adjustment to how the mobo is seated.
Anytime you remove the heat sink, you should clean off the old paste and then apply a new layer.
I still have one of those Xigmatek backplates stuck to an old motherboard. Afraid to try and take it off.
Just be careful not to rip off any resistors or anything else when you remove the back plate. Remove it slowly. Very slowly.
