Removing window from Antec/Cheiftec panel??
EPS Sniper
I'm having my Antec powdercoated (it's finally getting modded :p ) and need to take out the plexi from the side window. It's got these rivet-like screws holding it on and I was wondering how I could safely take out the window so that I can have this thing powdercoated and put back together. Thanks as always :)
look at the inside of the panel, those little rivet like things allow you to take the window off. basically what you have to do is take a pair of pliers or something and sqeeze the two tabs on either side of the holding pin and push it out
