removing video card question
creepcolony
i am gonna get a new computer and will be moving my radeon 9800 from my old computer to the new one. my old computer has nvidia geforce 2 integregated graphics which i will be using after removing the 9800. now my question is, should i uninstall the catalyst drivers first or remove the card first?
also, when i install my card on my new comp, should i install DirectX 9 first or catalyst first?
You probably won't be able to use the integrated gfx and the AGP card at the same time.
You should always remove the old drivers first.. unless it is the same brand. But since your integrated gfx are geforce... remove the drivers first. I would personally format the hard drive, but thats up to you.
