Removing UV Dye Stains
Arcygenical
Does anyone know how to remove the stains that UV dye leaves behind on your tubing? I have this orange colour which realllly doesn't match what I'm planning on doing XD.
I have Masterkleer tubing, if, you know... you needed to know that :)
I pushed alcohol soaked chunks of paper towel through mine. That got them pretty clean, but then I went ahead and replaced them anyway. I decided to change the routing and stuff.
