Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
best thing to do is run your comp for 15 mins or so, this should sufficiently heat the compound between your hsf & chip enough to make it easier to remove. Then simply lift off the old unit!
