CompMage
- Sep 7, 2003
Ok I know I've seen a link to a how to around here somewhere I just can find it. I need to remove the stock heatsink on a BBATi Radeon 9700 Pro. Thanks.
Originally posted by thebro
how do they tell?
what if you put it back on![]()
i had a pelt on my gf 4 and it went out then rma'ed it and they never knew![]()
Originally posted by Magic H8 Ball
Nice to see that kids today have strong ethics.![]()
Thank you for making hardware prices higher for all the rest of us.
Originally posted by Syphon Filter
riiiiiiight....
Anyway...yeah just take it off, it should be pretty obvious...either the pins will just push through or there may be a screw, I have not seen a 9700 so i cant be sure but looking at my 9800 its just held on with a couple of small screws. And yeah keep hold of it...as long as you are careful dont worry too much.
riiiiiiight....
Originally posted by waddles
Once you get it off, isopropyl alcohol is your savior for cleaning... never knew it worked that well until today!![]()
well i guess i would be a 23 year old kid![]()
also i myself do not make prices go up. hell it wasn't even my fault for it breaking. a cap blew, i didn't fry it.
not like im ocing a p4 to 4.0 ghz then rmaing it
understand where you all are coming from but i did not kill the card
Originally posted by slaya
Hey to tell you the truth if I break my hardware on my own mistake the first thing I do is return it.. if I cant I get sneaky and buy the same product and stick my broken one in there.. it always works.. unless I buy it form an online store I dont bother than..
They make a 5x profit on these things why not take advantage of them as they take advantage of us?
