Feb 22, 2008 #1 O omega-x 2[H]4U Joined Jun 21, 2003 Messages 3,073 Have a dell 2007wfp with a subtle but not invisible scratch when the screen is white near it, anyone know any good ways to buff it out without fubaring the area around it?
Feb 22, 2008 #2 C CoolGuy90 Gawd Joined Oct 1, 2007 Messages 649 Sounds silly, but might just work: http://www.wikihow.com/Fix-a-Scratch-on-an-LCD-Screen
Feb 22, 2008 #3 S switchg3ar Limp Gawd Joined Jan 1, 2007 Messages 143 There is no way of buffing it out, if you do try and buff it out you will take off the anti glare coating and you will be left with the shiny spot. There might be a way but chances are you are going to make it worse before you make it better.
