Removing scratches from clear plastic case side?
Standpoint
I recently got an Apevia case for a friends PC build. On the inside of the clear plastic side, it appears like the cabling for the front audio/USB/Firewire have seriously been brushing against the inside of the plastic, causing some scratches and marks. I do not want to RMA the case if I can avoid it, and believe that it would be likely to get another one with a similar problem.
Does anyone have a good method for removing these scratches?
Thanks,
Meguiars also makes a product called "Clear Plastic" which is amazing at removing scratchs on clear coats and plastics like plexi.
Thanks for the replies. That Novus stuff looks like what I should get, but I like that I can get the other stuff next to my house. hopefully the scratches aren't too bad, and the auto stuff will remove them.
