Removing rivets. Questions.
kuhla
Should I invest in a rivet remover tool?
Drill them through?
Hammer them through?
Cut one side off?
EDIT : Sorry everyone.... newbie moment... didn't search and found my answer by searching. Mods please delete this thread I can't find a delete thread button of any sort....
Find what size they are, usually 1/8th inch and drill it right through.
yeah take a 4mm drill bit and drill the heads off (Flat side) and bingo job done :D
Yeah drill'em out. I removed a riveted drive cage in my antec case I am working on in like 2 mins flat.
The only way i've ever removed rivets is by drilling... what exactly is this rivet rmover tool you speak of? other than a drill bit?
