L
lordnikon
Guest
which dremel bit u would use, would best be use drilling the rivett?
No dremel. You drill out the rivets with a drill. You use a drill bit in a drill. At least I think that's what you are asking(I just picked out the key words and went from there).Originally posted by lordnikon
Except that your standard Dremel rotates in the opposite direction of most drill bits, that is to say, couterclockwise.Originally posted by DeViLdUdE
I think the largest "DRILL" bit you could slide in the dremel would work in kind of low speed. Better if you have a chuck that could fit bigger drill bits.
