Silent Assasin
- Aug 1, 2004
Which is the best way to remove thermal paste..... After tons of work with my new setup, I just don't think i'm getting a good contact. I installed my DD TDX block for socket 754 using AS5, but my temps did not vary at all from what my air cooled cpu was.... I thought that after letting the AS5 settle a bit, that temps would drop, but in my case it's exactly opposite. With my old HSF I used some really cheap thermal compound that came with my Chaintech mobo. When I removed the HSF I scraped off as much thermal paste as I could with an old plastic cards and then dabbed the rest off with alchol and paper towel...... Was this a bad idea? After doing everything I could it still seemed like there was a tiny coat of the old paste on my cpu, the lettering was still odd colored....
Also while screwing with my tubing and wireing I bumped my block pretty hard which made it shift a bit. So it needs to be reseated anyway, but this time I'd like to do it the right way. I will probably use some more AS5 unless you guys would suggest against it. I would go with ceramique but I can get the AS5 for nearly free from someone....
