Removing old bootloader entries
Ok, well I have 2x250gb HDs in RAID0 that I have Windows installed on, and a wd640aaks as my storage, but about a month or so ago a corrupted Vista disk resulted in a few botched installations, and the boot info is still somewhere in my storage drive
Searching the drive shows many bootmgr.exe.mui files (languages) but I don't wan't to delete them if they effect my current setup.
I wouldn't assume they would, because if I unplug my storage drive the Windows 7 bootloader still loads as it should (dual booting XP and W7 right now)
msconfig > Boot [tab] > Select whatever entries you want to delete and press the "Delete" button.
Use this, it's free.
http://www.vistabootpro.org/
Hmm, just looked at the url again and now they want money for it. I got it for free quite a while back. Same as BCEDIT anyway but with an easier to use interface.
Hey, thanks for the link. Not for the easybscd but I see they also have a tooltip fixer.
http://neosmart.net/dl.php?id=10
That's been an annoyance I have hated on XP for a looong time. What's the point of tool tips in the system tray if they are hidden behind the task bar? This supposedly fixes it.
