Removing Northbridge cooler...
mr.dearthian
I tried posting this over in Intel Motherboards section (since it is an i875 board) and got no response. So I thought I'd try the general motherboard forum to hit a wider audience.
I just got a passive Northbridge cooler by Zalman and I am having a bitch of a time getting the stock cooler off. It is the mounting posts that don't want to pop off (the plastic ones). Here's the board I have:
Gigabyte 8KNXP rev.1
Is there anything I have to do on the back of the board to get the cooler off? It didn't even cross my mind to do this before I mounted the board in the case (DOH!!!). Is there anyway of safely removing it without removing the board from the case? If not, I'll break down and remove the board (I'm kinda lazy about this and really don't want to; but will if it's the only way).
Thanks,
Mr.Dearthian
the plastic pins have two well i will call them prongs that stick out and hold them it to the board, look on the back, squeeze the prongs in and it will come out
