Removing heatpipes from Mobo
Gyrfalcon
I am looking at replacing the northbridge cooler on an Asus P5N32-E can I cut the heatpipe or do I have to take it off the mosfets too?
A heat-pipe has no moving parts (there's a fluid of some sort inside that moves as it heats/cools - might be water, might be some other medium), but sawing it into pieces would make it stop functioning as it was designed... making it just another hunk of metal.
So he shouldn't cut it?
I want to keep the fins over the mosfets but I am going to replace the northbridge cooler, I realize the fluid will leak out, but is this stuff toxic?
Wear plastic gloves and take it completely off before cutting it?
I was trying to avoid advising one way or the other :)... (I have no first-hand knowledge) I _think_ they are sealed in a vacum or semi-vacum (sp) state. But yeah, IF you decide to saw through it, I'd certainly remove it from the board first and at least wear some sort of protective eye-wear.
Went and checked out the chemicals in the heat pipes for PC applications, looks like they are safe to be around (at least according to MSDS). Now I just need the board to show up.
Just my 2 cents worth, but kink the heat pipe between the two parts so it will not leak then cut it and it may be possible to save the fluid inside it. But I do agree with the other member do not try anything while still attached to the motherboard!
Hopefully that happens pretty soon, I wanna see the goop.
Reminds me of when my teacher and us upperclassmen went out with a sledgehammer and smashed an old dead laptop to see if it really was liquid in the screens.
i had a striker extreme that actually caught on fire on on and i decided to cut the pipes for the hell of it. it was kind of a paste like sandy gritty substance in the pipes. now mabe this could heat up and becaome a semi-liquid or whatever but it wasnt a dripping liquid.
