Removing ATI/AMD drivers, help needed
stevelopez91
Hey all, it's been awhile since I've done a clean driver reinstall, and sadly, I sort of forgot what program to use. I'm going to reinstall the 12.4 drivers because starting today, I started getting random freezes that lasted for 1-2 seconds while playing Battlefield 3. They come about every few minutes or so and have rendered battlefield virtually unplayable. I'm currently running a 7970. Anyways, any help on a clean uninstall, or even input on what the problem might otherwise be, would be very much appreciated. Thank you.
No program needed, go to Uninstall Programs and uinstall the AMD Catalyst drivers there. Then re-install the new Catalyst drivers after a reboot.
