I have an Athlon XP2100, and I recently had to remove the stock heatsink for the first time since installing it.
There's some nasty light pink hard waxy substance that was used as the original heat conductor, but I can't get it off now without chipping it off with my fingernails, which isn't very efficient. And I'm not about to try that on my CPU core...
I've tried isopropyl alcohol and it doesn't come off with that either. Does anyone know what you're supposed to use to get this stuff off? (sorry if this has been covered before, but the search function doesn't work)
