goo off would leave your cpu orangy fresh!dr_dirtnap said:Try some Goof Off (found at Walmart) and some high purity rubbing alcohol.
Binkt said:I was using ethanol until I tried WD40. It is WAY more effective! a tiny spray on a rag and a quick wipe - GONE!
Try it, you'll like it.
Use alcohol.Arctic Silver said:Never use any oil or petroleum based cleaners (WD-40, citrus oil based grease removers and many automotive degreasers) on the base of a heatsink. The oil, which is engineered to not evaporate, will fill in the microscopic valleys in the metal and significantly reduce the effectiveness of any subsequently applied thermal compound.
I have used goo gone on every cpu and gpu I have had to clean for the past 6 years.ryuji said:goo off would leave your cpu orangy fresh!( i think it will leave a residue thats prob hard to get off since it seems to be a oil)
