Phaedrus said:You can also goto start/run and type "msconfig" "enter". On the BOOT.INI tab you can modify the boot.ini file. One method is to set the timeout to 0 instead of 30, making sure the installation you wish to boot to is the default. That way you wont lose the other entry if you need it later. Or you can remove the other entry altogether.
