travbrad said:What's the best thing to use for removing the thermal pad gunk from my A64 X2? It's really sticky/difficult to remove. I want to try some AS to see if that works better than the amd stuff (that and i'm going to be getting a XP-90C soon)
travbrad said:I'm just going to get some arctic clean with my new HSF, might as well since it's only $5. Anyone know how many uses the small (60ml) bottles are good for?
SpoogeMonkey said:Unless AMD has changed their warranty specs, I wouldn't remove the thermal pad, since you're getting better hsf anyways. Last time I had to send a cpu in for warranty, they wanted/needed the stock hsf with the melted t.i.m intact. Technically, using ANY thermal material other than the stock "crap" voids your warranty and it's at their discretion whether or not to honor your warranty.
I'm not saying they're total dicks, this is what was required for me to get my 1800+ replaced. At best, you could get 5-6c improvement, but isn't the sanctity of your warranty more important if you're getting an xp-90 "real soon"?
