The Preshot IHS is glued to the core with Some sort of thermal epoxy, unlike the Northwood which uses Thermal compound.
Googling brings up a couple of sites which advize against even trying to remove Preshot IHS's, as the core breaks!
Does anyone know of a guide using heat/cold/solvents or something to sucsesfully remove the IHS on a Prescott??
