Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I have a ASUS P4Pe mobo and a 2.4b with the stock hsf. It has 2 white clips on the side (its the stock intel hsf) Is there a special way i am supposed to do this? Each time I have tried I could not get it off.
Release the white levers, then for each of the four legs, you have to press down towards the MoBo just a little bit while gently pulling the leg out of the mount on the motherboard. It doesn't take a ton of force; just be gentle with it and it should come right out / off.
