Here's the deal.
I have a 2k Server that is my AD server.
I just setup a 2k3 server.
I ran adprep on the 2k server
I added the 2k3 server to the domain.
I then moved all rolls over to the 2k3 server
I made the 2k3 server the global catalog server
I setup dhcp on 2k3
I setup DNS on 2k3
No I have backed up everything on the 2k server
I'm now trying to demote the 2k server so I can remove it from the domain.
I'm doing this so I can format the 2k server and install 2k3 using the same computer name.
Well when I try to run dcpromo I get an error saying:
If I open AD and check the operations manager it says "ERROR"
If I connect to the 2k3 domain controller then check operations manager it shows the 2k3 server as the operations manager.
The 2k3 server has RPC running and it does not have any firewall or av running yet.
Any clue as to how to remove this domain controller?
I setup dhcp on 2k3
I setup DNS on 2k3
