"Remove seal after washing" sticker
SilverMK3
picture: http://www.viavpsd.com/product/4/8/P1010007a.jpg
Any idea why there's a sticker saying "Remove seal after washing" on what looks to be a capacitor on this picture of a VIA Epia MII motherboard??
I'm looking into putting together a car-pc with one of these, or maybe wait till the nano-ITX boards come out. Either way, what's with the sticker?
perhaps somewhere in the manufacturing process, the board needed to be washed of chemicals....and the seal is over the battery...wouldn't want stuff hiding in the battery.
Wash it, then when they refuse to replace it, sue them to the effect that this sticker implied that you should wash their product.
j/k
Really, probably what Fark said... but it is strange, I shall send this out in the weekly office newsletter.
The component you identify is a solid state buzzer / speaker of some type; very common on MoBo's anymore.
Every PCB gets washed after the soldering process. How it gets washed, and what it gets washed with depends on the soldering process (reflow oven, wave, combination, etc.). Belive it or not - water is used in some processes. These little speakers can be wasted by some washing processes and the little sticker keeps the component from filling up with liquid.
The reason you have to "remove the sticker" is that it covers the opening that allows the sound from the speaker to radiate. It'll work, it'll just be very quiet. I often leave them on for just that reason..... :cool:
Party On - B.B.S.
Party On - B.B.S.
I see it now...definitely a speaker. Compared to the via chipset chips, it'd be too small for a battery. Odd though, I don't see a battery for the bios chip. They wouldn't have put it on the other side would they?
