Remove PGA370 socket from VP6?
jordan172005
I bought a Abit VP6 a while back and when I got it he had some dumb hsf that was very hard to get off and you had to stick something in the clip to get it off. Well I got a screwdriver in there but evidently not secure enough because it slipped and cut 4 traces and the board is now unstable. The 4 traces are right above the bottom PGA370 socket and will be nearly impossible to get to so I can repair them. Is there any way I can remove the socket from the board so I can repair the traces and then put the socket back on? This VP6 is my dream board and I ruined it before I got to use it :( any help is greatly appreciated.
Thank You
I might be able to fix the circuits with a conductive pen but if I can remove the socket without much hassle could someone please let me know ? Thank You
I believe removing the socket would be a hassle. however, if its your dream board, it might be worth it :p
