Remove Manfacturer's Badging/Branding
willie92
Anyone have any suggestions for removing the Cooler Master lables on my WaveMaster? It's brushed aluminum, so it should be able to standup to some pretty harsh stuff, I just thought I'd see if anyone had some good suggestions...
Thanks!
I use goof off. its this horribly rank stuff.. i used it on some front bezel plastic once and it melted it.. also do not use it on painted surfaces.. it will destroy the finish.. maybe even remove it. paint thinner works to but iv never used it. clean it with soap and water afterwards to remove residue.
