My friend said that on the Seagate drives that you should remove the jumper from the drive to enable SATA II, otherwise, if the jumper is installed in default MASTER setting, the drive does not perform at SATA II levels. Can anyone confirm or deny this?
What is the best way to test or benchmark a drive to see how it is performing? Thanks...
