Remote Reboot
mwolfod
I have a remote PC which occasionally "locks up" requiring a cold restart.
I am aware of the numerous products which allow for a remote power cycle, but this particular situation requires a physical press of the front PC power switch in order to properly reboot the PC.
I'm not sure how to approach this problem (different case/power button, BIOS settings, remote power-cycle hardware), and would appreciate any suggestions.
Thanks.
Thanks, but I'm not sure how that is any different than any other remote power cycle product.
Again, when this computer "freezes", I have to phsically depress the PC power swith to reset it.
I'm sure there is a solution, as IT pros deal with similar problems routinely.
My lack of knowlege however, is preventing me from perceiving a workaround for the (simple?) PC power switch issue.
Do you have a separate IP/Ethernet connection available for that device?
You could always just hack together an Arduino + Ethernet Shield + Relay/Transistor and wire that onto the power button of the box, that way you could write a simple sketch which allows you to "press" the power button from the comfort of your own computer.
If you'd like, I'd even write the sketch for you (and even the transistor board possibly, fun project for me), all you'd have to do is solder together the transistor/relay board and get a arduino + ethernet shield (Arduino's are available at Radioshack, the ethernet shield you can buy online)
