Remote Desktop/VNC bandwidth use
MJCfromCT
Hi everyone,
I'm curious as to how much bandwidth these protocols use if the remote desktop/vnc window is minimized? Is bandwidth use cut down to zero if the window is minimized? Thanks.
I can't give you a definite yes but I'm going to say that they do or its very little. I do know that the VNC Client seems to sleep most of its network activity when its minimized, I base this on two key behaviors that I've noticed.
the VNC client will not update the screen while its minimized, it will wait until its viewed or explicity asked to refresh to do so.
Many many times the VNC Client will not even know if the server is missing while its minimized, that is if connection has been lost due to network issues or if the services was killed abruptly.
However to find out its easy. Get two computers whatever VNC you want and open a session, on the server... scroll a page a few times over and over. Read the bandwidth used on the client with the free net meter program. Minimize and repeat and see if its the same or less.
I can confirm that when Remote Desktop is minimized, it doesn't use any bandwidth at all, it's not until you bring up the screen is the picture updated. When you're using it, it uses such a small amount of bandwidth anyways, all it's doing is taking a picture of the server and relaying that
Remote Desktop/Citrix was optimized to use up to 24k by default, when in session. I recall reading somewhere it drops down to 4 or 5k when minimized.
VNC seems to use more...or maybe that's just the appearance because it's more sluggish.
